Thread: throttle cable replacement help, please
    L. A. Guest
    Question throttle cable replacement help, please
    I'm replacing my throttle cable...last one kinked somehow, just about 6 " above the carb...
    The housing's fine, so I thought I'd just replace the cable itself.
    My question is: Is lithium or simply WD-40 OK to use to lube it up before inserting it into the housing, or is there something else I should use?
    I'm gonna try and do this without removing the housing...but maybe this shortcut's not a wise move???
    'Preciate any input...
    Jim M Guest
    A light coat of oil is all you need. Lithium is too thick and will attract and retain dirt. WD-40 is not a lubricant but was intended to be a water drying compund for electronic parts. I've been using oil for years trouble free.
    Jim
    L. A. Guest
    Thumbs up On the road again................
    Thanks to all who replied...worked out great...easy fix.
