Results 1 to 2 of 2
Thread: 4 speed shift lever hole size
    DanMargolien Guest
    Default 4 speed shift lever hole size
    Hi everyone! Looks like everyone went on vacation- but here's a quick one:
    On the transmission shift lever, the dog legged triangular piece with 3 screws to the shift selector drum cover- what size is the holde for the clevis pin? Should there be a bushing in the hole?
    Mine has nice round hole, but it is about 1/8" diameter larger than the clevis- Imade up a nylon bush- but how was it originally ?
    Thanks again! Dan
    Perry Ruiter Guest
    Orginally there was a steel bushing (34428-52) in there. I have
    an NOS one and the ID looks to be .255 - presumably the
    clevis pin is 1/4 inch OD or just a hint under. The OD is .377 so
    if you're missing the bushing there's your 1/8 inch extra ... Perry
