Results 1 to 10 of 11
Thread: paint color
    excel15 Guest
    Default paint color
    Can anyone help me with the correct base color for a 1915 Excelsior? I know it is a light gray, but is there a particular brand and color name that I can get that is correct? Please respond to my Email - bas2910@aol.com Thanks
    capa Guest
    Default Excelsior Grey
    There's a near perfect color match to Excelsior's "French Grey" available in a spray can!
    It's a fast dry enamel by Varsity called DOVE GREY, P-364. I got mine at PEP-Boys automotive for about $3 per can, but I think you can also order it direct thru Carrus Supply Co. 1-800-934-3666 but it will be much more expensive thru them.
    Jerry
    Apr 2013
    3
    And can anyone say what the right blue color is for an Exxcelsior serie 20 yar 1921. I have seen light blue and very deep blue..There ought to be some general description.The only one i know is deep royal blue. This was what I found on the handlebars.color swedish excelsior.jpgBlue colour_redigerad-1.jpg
    3,792
    Excelsior, and Henderson used a very dark blue, often referred to as Packard Blue. In low light, it looks black. I had a series 20 Excelsior which I got from a very knowledgeable Excelsior collector. He had a number of original paint parts and due to age, they looked black, until you wet sanded them to reveal a very dark blue. On a Series 20, most everything is painted dark blue, with the exception of the headlight, horn, horn bracket, ammeter brkt. tail light, and fork rockers. If you're lucky enough to have the Midco generator, it would be dark blue. The following pictures are of my '17 Henderson which is painted with a NAPA Dodge truck fleet color I got from Dick Winger. Unfortunately NAPA discontinued a huge portion of their catalog and that color was among them.
    3,792
    I should mention that ancillary parts on the Henderson are painted black; like the seat springs wheel rims, handlebars, rear stand, so you can see that in low light, the black, and blue almost look the same.
    Apr 2013
    178
    I don't want to "hijack" this thread but I am wondering if there is a modern equivalent paint for series 18/19 excelsior ?? I asked this question in the "American Other" section but just noticed this and thought the question is more appropriate here ,
    as always, thanks
    Dan
    3,792
    Dan, this is a spot on paint formula for the drab green Excelsior, and Henderson used from 1917-1919. I was not able to get it mixed on my last try because it is formulated with Centari color numbers; which are obsolete. Please let me know if you can find someone that can do this.
    5,206
    As far as judging goes we look for the color and not so much the shade of the color as paint varied from batch to batch,
    3,792
    I believe you are right, Chris. I wonder what a batch quantity was, and how accurate a paint mixer was if he was mixing 100 gallons at a time.
    May 2016
    Melbourne, Australia
    24
    Exeric, my 1923 Big X still has some original paint left and I agree it is a very dark blue color. The handlebars appear to be original paint and they are black like the Henderson of the same era. I think the footboards may have been black as well if you go by the little bit of paint left. Tinware, frame and forks have all been dark blue. Wheels are grey, spokes and all with a black line (I assume its not just dark blue that has got darker with age) on either side of the rim.
