Results 11 to 20 of 27
Thread: UL frame identification
    Hi Eric,
    Also please let me know where does this speedometer cable clip fit.
    If possible supported with a picture.
    Regards,
    Shyam.572BFCA6-6E2C-4605-B1B1-166C6D26B0CA.jpg37512E67-F45F-4492-A60E-BDF2626B1936.jpg
    5,467
    Jun 2010
    295
    Under left rear cylinder nut.
    Quote Originally Posted by 1950Panhead View Post
    Thank you Eric.
    Mar 2010
    Western Australia
    78
    On the left axle clip the die number looks like 5 and apparently 5 was used for about 194144. On the steering head the die number looks like 8 which indicates 194243.
    Both those die numbers are consistent with what the other two die numbers were suggesting: a 1943 model frame.
    Eric
    Quote Originally Posted by Speeding Big Twin View Post
    Eric
    Thank you Eric.
    Quote Originally Posted by shyambiker View Post
    Thank you Eric.
    Hi Eric,
    Can you please let me know where does this Speedo clip fit on the ul.
    Part no : 67075-36
    If possible a picture please.
    Regards,
    Shyambiker.
    Hi Eric,
    Part no : 67075-36
    Regards,
    Shyambiker.
    On center case stud just above VIN No.
    Quote Originally Posted by Kozy View Post
    Thank you kozy.
    Can you also please let me know where does this throttle bracket fit on the cylinder head.07DB2166-E18A-4E91-B2D2-E7A01AFE1B6B.jpg07DB2166-E18A-4E91-B2D2-E7A01AFE1B6B.jpg
