Results 1 to 10 of 19
Thread: 59' Panhead Frame
    Default 59' Panhead Frame
    I'm looking at a 59' Panhead frame and looking for any info that can help me identify if it is a Harley frame or reproduction, Casting numbers or other identifiers that would or should be there.
    67 Shovel
    Jun 2010
    295
    47591-35 left side dash mount
    DIF31 or DIF32 right side dash mount
    Top motor mount has date code 8F to 9F for 59
    Perfect.. Thank you!
    What about MM59 on the upper motor mount?
    Jun 2010
    295
    That would be unusual, post a photo.
    Having trouble getting a picture since he is 3.5 hours away from me. His pictures are blurry, I may get to see the frame this week, if so I will post.
    Mar 2010
    Western Australia
    78
    sieber60, for 1959 model H-D Pan steering heads at least two forging numbers were used. One was 47591-35 as mentioned above. The other was XE-35F.
    For a 1959 model steering head at least four die numbers could apply. Mentioned above are 31 and 32. The other two possibilities are 29 and 30.
    Lower left rear forging should have 47653-58 which was used for 1958 thru about mid-1970.
    Lower R-H rear forging should have 47651-58 which was used for 1958–early-1973.
    Both upper rear forgings had a certain forging number for 1958–64 but it was done in at least two ways: 476 45 58 and 47645-58. Notice the spacing. Notice the first version had no hyphen. For a 59 model frame I imagine the first style would apply.
    There are also other things to check so I look forward to the photos.
    Eric
    Quote Originally Posted by Speeding Big Twin View Post
    Eric
    So got my hands on the frame.
    Left side of dash mount 47591-354
    Right side dash mount - DIF31
    Upper motor mount- B9
    Mar 2010
    Western Australia
    78
    Quote Originally Posted by sieber60 View Post
    47591-354?
    Or is it 47591-35A?
    Or is it 47591-35?
    And what happened to MM59? Please post photos of all markings and photos showing both sides of the entire frame.
    Eric
    Here are some pictures, unfortunately my camera is cheap so the numbers are hard to make out.
    The MM59 was apparently a different frame. He had another frame that looked like the upper motor mount had been altered.
    P1010022.jpgP1010023 (1).jpgP1010021 (1).jpgP1010024 (1).jpgP1010016 (1).jpg
