Results 1 to 8 of 8
Thread: Rear wheel ideas?
  1. #1
    Default Rear wheel ideas?
    1972 small stroker Shovel with 2002 TLEU sidecar and broke a spoke on original rear wheel (no shame). Wore off a Shenko tire after putting sidecar on so switched to darkside with a Coker 5:00 x 16 car tire and think the stiffer tire accented the sidecar strain to rear wheel. After all those years the broke spoke is probably a sign of things to come. The car tire looks as new as the day it was installed so would like to keep running them. Are there better/stronger than OEM spokes and rims? Am partial to the round swingarm and drum brake but could change over to cast wheel, disc brake and new master cylinder? Have a 9 spoke 2002 front wheel that would look great mated up to original drum and sprocket just don't know if I want to tackle a job that size.
  2. #2
    Sep 2005
    Sarasota, Florida
    4,176
    I had a sidecar on my 1951FL. A sidecar is hell on almost every part of a motorcycle, but also fun and that is the trade off. H-D spokes, and nipples are quite stout so I don't know if there is a stronger upgrade. I guess Buchannan's could advise you on that. Alloy wheels are probably the best long run option.
    Quote Originally Posted by exeric View Post
    Thanks.
    Have never used Buchannons, will give them a call.
  4. #4
    Jan 2006
    Menomonie, WI
    1,274
    Don't use stainless - they break faster than OEM,
    Quote Originally Posted by Bubbalowe View Post
    Thanks.
  5. #5
    Jun 2009
    TN
    300
    Agree with Jerry about stainless. I have broken many spokes on my 33VC with sidecar. Buchannon has heavy duty spokes that will help but the biggest issue is the side forces out on the rear tire and the fact that stainless "work hardens" and then breaks. When Harley shipped a bike with sidecar from the factory back in the day of spokes, they used heavy duty spokes.
    Bob Selph
    1933VC/1934LT Sidecar
    1940 Sport Scout
    AMCA#15215
  6. #6
    Oct 2009
    west bend wi
    60
    Your spoke broke because the are loose. Replace your spokes with a standard spoke and keep your wheels maintained.
  7. #7
    Sep 2005
    Sarasota, Florida
    4,176
    This thread brings up an interesting question. Did Harley-Davidson make their own spokes, or did they have a vendor? In the early days of motorcycle manufacturing, most manufacturers got their spokes from Torrington. Big companies don't want to re-invent the wheel so I have to think H-D had a preferred vendor.
    Aug 2004
    Beautiful Northern New Mexico
    2,794
    Quote Originally Posted by 34 cac View Post
    This is the best answer yet. I have run a sidecar rig for over 40 years and have never broken a spoke, including rough use. I regularly ride it on dirt roads and with heavy loads.
