Good advice. I don't glass bead any motor parts, and particularly aluminum castings. I clean castings in our laundry sink and use anything from TSP, Comet, Dawn, scrub brushes, scouring pads, and tooth brushes. You'll never make your cases look like they did when H-D put them in a frame, but you can come close.
I've found embedded glass beads in the surfaces of carefully cleaned aluminum castings, and in other very bad places (behind races, blind threaded holes, inside oil passages, snap ring grooves, etc.).
A few thousand vibrations later, they reappear and flush through the oil system as an abrasive slurry.
A friend, as an experiment, blasted a piston. He then scrubbed it with detergent and hot water. He then put it in a pot of water and boiled it. When he finished, there was sand at the bottom of the pot.
I would put the cases in front of a space heater ,then hit with a foam type degreaser and scrub brush..Dont glass bead.
That would just be more junk science, Mick!
There are over a hundred and fifty Federally-allowed additives, and combinations are more digestive than any alone.
Injector cleaners, mandated Intake Valve Deposit inhibitors (IVDs), "detergents", etc. are why plug reading is now futile.
Ethanol just makes them all worse.
PS: Even if ethanol-free fuel was available, who wants to only ride in a circle around that pump?
Glass beading will close the pores on aluminum castings so it will capture the beads. If you have to clean use silica sand for the media, it will not close the casting pores and leaves a satin looking finish. Silica is another grit that must be removed from the castings before use as in scrubbing, washing very thoroughly.
