Results 1 to 10 of 20
Thread: 47 Knucklehead broken front motor mounts
    Aug 2014
    Ohio
    31
    Default 47 Knucklehead broken front motor mounts
    Good Morning,
    I have a 47 FL Knucklehead engine with both front motor mounts missing some chunks. Does anyone know a shop in Ohio that could repair these?
    Thanks,
    Eric
    May 2009
    144
    Have a photo?
    Aug 2014
    Ohio
    31
    Aug 2014
    Ohio
    31
    Aug 2014
    Ohio
    31
    Not sure why the pictures rotated sideways
    2,797
    Quote Originally Posted by underwel View Post
    Because you took them with your phone...
    Nov 2018
    Reno NV
    208
    I use my phone for any photos I take.
    Download to lap top.
    Occasionally the photos will rotate when uploaded.
    I have to go back to the lap top, rotate the photo and save, rotate the photo back and save.
    Then upload the photo again, It usually comes out correct.
    Annoying glitch somewhere in the process.
    Feb 2016
    480
    Hi Eric,
    Try George 'Geo' Roeder. Or--he'll have a line on someone that could repair it locally.
    Good Luck.
    https://www.roederracing.com
    *M.A.D.*
    4,349
    Don't look bad, Eric!
    But better fix them before the skilled pass on.
    Nobody local left here.....
    PS: ....I suggest piston rings for filler rod.
    (Peen every "bead".)
    Silicon Bronze is really hard to dress.
    Silversolder is great for cosmetic filler, and re-attachments.
    May 2009
    144
    Aluminum, no?
