Results 1 to 10 of 14
Thread: Belly Numbers
    Nov 2018
    Reno NV
    208
    Default Belly Numbers
    I have some J/JD cases that have different types of belly numbers.
    The earlier cases have two letters before the number sequence, while the later ones have a self explanetary two numbers for year stamped format.
    My question is do the earlier letter codes relate to any years that they were stamped, similar to transmission date stamping.
    5,467
    I bet George Hood can answer that.
    Apr 2010
    1,126
    I had 2 1915 J motors,early & late & the bottom numbers looked like different format from each other
    An early 1920s right case on my wall has B3 space 890 bottom number..my clock!
    Nov 2018
    Reno NV
    208
    I have a set of cases labeled XO-xxx belly no, with a 25JD engine no.
    Also a drive case with a H4-xxx belly no and a 24JD engine no.
    The number after the letter is a year code. It is the year in which the line bore number was STAMPED and could be a year earlier than the model year of the engine.
    Your X0 / 25JD case is a mystery. Can you post a pic of the vin and the line bore number?
    Is it a large base case? Does the vin look factory or like a re-stamp?
    Mark
    Apr 2010
    1,126
    Thanx Mark,I thought this was a 23 case
    Nov 2018
    Reno NV
    208
    Mark
    Thanks mark, I will get a photo later today.
    Nov 2018
    Reno NV
    208
    Here are some Photos of my 25JD cases.
    I suspect the X0 belly number is correct as a set of 1920 cases.
    The VIN no boss looks to have been removed at some stage and restamped, or it is a set of replacement cases that were stamped by the dealer.
    5,467
    [QUOTE=aumick10;184764]Here are some Photos of my 25JD cases.
    It is definitely a number job.
    Nov 2018
    Reno NV
    208
    I though it was after I measured the cylinder studs. It is a small base case that I don't think existed in 20, If the XO is a 1920 belly no.
