Results 1 to 10 of 12
Thread: J B Weld or locktite
    Default J B Weld or locktite
    Want to replace bushings for clutch lever on servi but one side is washed out some. hole is ,504- .520 bushing o.d. is .500. Will J B Weld do the job and if so which number? I see there are a lot of them listed. How about Locktite? Many moons ago we used a lot of them but can not remember which one for steel to cast. Help has always been great coming from you guys. Hope to hear more. Thanks
    Dec 2006
    1,288
    buy a new clutch lever.
    I worded it wrong. Bushings go in the sprocket cover. The lever pivots on them. It looks likes that cover is had to find.
    Nov 2010
    163
    There are a few servi-car sprocket covers on Ebay right now. It just depends on what year you are working on. Also, Throttle Masters in Chicago used to have a lot of servi-car parts.
    Craig
    2,764
    I have a complete assembly available. I would have to inspect it to see the condition of the bushings. Let me know if you are interested.
    Robbie, it is a 69 with electric start. Thanks for the offer. Part no. for cover is 34871-64. 64 being the first electric start.
    2,764
    Quote Originally Posted by jug View Post
    No problem, that one may be tough.
    Sounds like weld it and rebore it.
    Jul 2012
    Inman, South Carolina
    63
    Colony and Flatland have the bushings you need
    RCamp, I have new bushings. Just need to make the one lose hole fit better. thanks
    Have not used J B Weld but I seen stories of it for other things like sealing nipples. Is it not good to use for this problem? Some of these parts are hard to find and very pricey. Help!
