Results 1 to 6 of 6
Thread: Throttle cable routing
  1. #1
    Default Throttle cable routing
    Hi Guys, another question on my 1971 FLH . I need help routing my internal throttle cable from the handlebars to the frame neck where I think it goes thru the bracket ( see pic ) then to the frame tab under the tank . Then I'm not sure where it goes . There is a tapped hole in the top motor mount maybe there ? I can't find any bracket in my parts catalog for final mounting near the carb ( bendix ) . I see one for 1972 , but what they did in '71 I don't know, I need help . Pictures would be appreciated . Thanks, Mike
  2. #2
    Jun 2005
    Northern Colorado
    840
    IIRC, the cable is held near the carb by the air cleaner support bracket. The bracket bolts to the underside of the rocker box, and to the backside of the air cleaner back plate, and uses a 9957 type clamp to hold the cable.
    VPH-D
  3. #3
    Thank you , VPH-D I mocked it up and the bracket I got with the bike looks like it has a mount for just the choke . Do I have the wrong bracket ?
  4. #4
    Jun 2005
    Northern Colorado
    840
    1970
    You have the correct bracket, my memory was wrong. The -76 parts book shows a 9957 clip and 5915B spacer on page 116, with the comment 71 and later throttle beneath tank.
    VPH-D
  5. #5
    Thank you for your help VHP-D , I have found all the clamps & guessing on the spacer , but I'm still stumped . I don't know the routing of the cable . Does it run between the tank & the frame , secured with the clamp to tab on the frame ( on the second tube under the speedo ) , then unsecured to the carb ? Or between the down tubes to the same tab , then unsecured to the carb ? Still wondering about the tapped hole in the top motor mount .
  6. #6
    Jun 2005
    Northern Colorado
    840
    I think the tapped hole in the motor mount is a Tilly remnant.
    VPH-D
