Results 1 to 4 of 4
Thread: O ring thickness
    Default O ring thickness
    Anyone know what thickness the o ring is that goes between the engine & the primary on a '71 FLH ? I've got a James gasket set and there are three of them . Thanks , Mike
    Oct 2016
    126
    The ones I have in stock are Cometic and measure aprox. .070. It should be the the skinny one in you kit.
    Mar 2008
    New Jersey
    80
    Be careful. If you use the wrong one, when you torque the inner primary, you will break the ear on the front of the primary. The thin one is the correct one.
    Thank you for the help , Mike
