Results 1 to 4 of 4
Thread: Help ID Indian sidecar connections
    Default Help ID Indian sidecar connections
    Can anyone help identify these front connectors? The one on the right seems to be for a 40s chief. Not sure if its used on a four also. I also have two different size rear mounts. Does anyone know what years used the smaller or larger rear connection. Actually, I'm not even sure how these are used on the rear. Can anyone with a 30's rigid four sidecar take pictures of their mounting brackets? Also I could use pictures 40s Indian sprung frame sidecar connections. If anyone recognizes the mounts in the last two pictures please share knowledge.
    Thank you for any help! Steve 646-645-1582
    I'd like to purchase a solid late model tub.
    ca
    162
    From my limited knowledge on side cars the third picture top left may be for a 47 chief rear side car mount, The top right may be military because of the color. Jerry Greer has a good picture of the 47 style frame even though one frame is a bit shorter, but all use the same parts. Find Jerry greer indian parts. go to 47 Chief find sidecar parts. You will find a good picture of all the parts. Hope this helps. Stan
    Thank you. Very helpful!
    ca
    162
    Some parts on ebay now under indian sidecar, like the ones in the third picture. Stan
