Results 1 to 10 of 16
Thread: Oil change
    Default Oil change
    I am changing the oil on my 1948 chief ,what convential oil should I use thanks jerry
    It doesn't matter as long as it is motorcycle oil which has EP additives for roller bearings.
    High-zinc conventional oils work well. I use 50W, either Brad Penn, Valvoline VR1, or Joe Gibbs Driven. You can order the VR1 from almost any auto parts store. For any of them, make sure you get the dino and not the synthetic.
    Jul 2006
    Central Florida
    938
    You won't go wrong with Harley-Davidson 50 weight or 60 wt, depending on the state of your engine. Readily available at any Harley Boutique by the quart or the case, and designed for Air-cooled internal-combustion engines exactly like yours. Valvoline Aircraft 50, available at any private airport is the other that will never harm your engine.
    Do folks use 50W for both the engine and the trans? I've heard some people use 50W for the trans, and others use 15-50 or 20-50. What's the consensus?
    Jan 2008
    480
    I have only used straight weight oils for a long time in multiple motorcycles from fours to twins of both Indian and H-D. Oil is cheap, motors are not.
    "W" is not weight, it's winter: the oil viscosity when it's cold = 23 F.
    Just a rumor: "The 1st number in the oil viscosity is the time it takes, in seconds, for cold oil to reach everywhere in the engine. 10W30 = 10 seconds. 50 weight = 50 seconds".
    Sep 2012
    Saltsburg PA
    350
    Quote Originally Posted by Lipdog View Post
    Primary and trans share oil unless it's been modified to separate them which some have been. 50 is too heavy for a combined primary and transmission. If primary and trans is separated, 30 can be used for the primary and 50 or even 80/90w would be fine in the transmission.
    I run Penngrade1 50w in the engine which is another oil specifically designed with old flathead air cooled engines in mind. If I was riding regularly in 85 plus degree ambient temps I'd run 60w. I don't run a Kiwi tank filter but opt to change it every 500-600 miles.
    HD Sportster oil in the shared primary/trans is used by many.
    Jason Z
    AMCA #21594
    Because it's an oil thread. Lubricating oil has constantly improved the last century and reason they didn't use multi-vis in the 40's was because they didn't have it. All modern motorcycles use multi-vis and in absolutely no way does it harm a Chief engine. I've ran it and makes kick starting much easier. Asked a Penn Grade (Brad Penn) representative why they continue to market straight heavy oils if multi vis is better and he replied for old guys my age that refuse to change. In the eighties I did the 3 oil separation by sealing primary to trans, the light gear oil didn't help shifting and the trans fluid made no difference in clutch, pulled the seals out and now use cheap sae 30, drop oil every year or no more than a thousand miles. What brand oil to use is over debated, it doesn't matter.
    Quote Originally Posted by Bubbalowe View Post
    So what weight oils do you use in the engine, primary, and trans?
