Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Carb adjustment question
    Default Carb adjustment question
    On the thread on Wet sumping, the conversation wandered to carb adjustment, so I thought it would be good to start a new thread.
    My initial question on the carb was: I just went to baseline the carb adjustments and was surprised what I found. The low-speed screw was only 7/8 of a turn open from seated. The high-speed screw was 1-7/8 turns open from seated. The baseline adjustments mentioned in the book are 4 and 1-1/2 turns, respectively. So the low-speed is set far leaner than the baseline, yet the plugs still fouled at idle. Has anyone seen adjustments this far away from the baseline?
    Cotten replied:
    Lipdog!
    Please make certain that your LS needle is 3.5" long, the spring in the knob is on top of the needle, and the lift spring collar is in place with the flat side down.
    I send M344s out set at three and a half turns on the LS, and one and a half on the HS, but that assumes a sealed manifold assembly.
    I think everything checked out ok. Attached below are photos of both the high and low speed needles. The spring loaded ball on the LS side moves nicely too, and it looks like it was rebuilt and cleaned carefully in general.
    Given it seems to be fouling the (Autolite 303) plugs while idling (the bike is not registered/on the road yet) for 10 minutes, and the LS screw is only 7/8 of a turn out, do you recommend I start over at 3.5 turns for the LS and 1.5 turns for the HS, or would that just give me a richer idle and foul the plugs more?
    Thanks!
    Apr 2010
    1,112
    All carbs need to be adjusted for the motor.
    You need to read the part after initial adjustments & do those adjustments.TWICE!!!
    There is no setting that fits all motors & carbs.
    4,292
    I'd first measure the 303s for resistance, Lipdog.
    Apr 2010
    1,112
    303 is resistor copper core
    Starklite calls for their Indian script = NGK B7HS or Champion J6..non resistor plugs
    I hate Autolite plugs
    4,292
    I just hate resistor plugs, Duffey!
    Or at least all of my coils do...
    PS: Lipdog!
    Lots of 'rebuilt and cleaned' carbs crossed my benches (back when I was accepting new accounts).
    The 'professional' "rebuilds" often weren't.
    Please inspect the gallery plugs, as one ebay hero was selling kits with set screws, allowing both fuel and air to the wrong places.
    I have a box of NOS J6 plugs so I will swap them in. I will also check to see if there is a wet sump condition and check for manifold leaks. I am thinking I should start from the benchmark that Cotton recommends (3.5 turns out LS/1.5 turns out HS) and work from there.
    Cotton: I looked on a number of diagrams (like this one: https://www.jerrygreersengineering.c...y=1952&m=Chief) and can't find parts called the gallery plugs. Is there another name and are they on this diagram?
    Thanks!
    4,292
    They're just "plugs", Lipdog,
    #1 on Greer's list, Indian OEM 102420
    They plug galleries, and your M344 would have four.
    I'd post a pic of the crappy kit with set screws and other issues, but the vendor isn't here to defend himself.
    PS: Wow, mine just went up a buck, thanks!
    Vermont
    742
    Whoa... 303 Autolite plugs work well in my Chief...don’t go bad mouthin’ my plug choice!
    In spite of two of the most knowledgeable vintage bike guys you’re likely to ever hear from, and they may be right, Lipdog...I’m thinking you just need to be patient. Slap a plate on that Chief and ride it under load for a while...see what’s up. You can chase problems all day long but without actually running the road, under load at more than an idle, I don’t think you’ll ever get an accurate picture what you’ve got going. Don’t go chasing a problem until you find out that you DO have a problem.
    Yeah, I get your point about chasing problems. But I don't think this carb is right. I swapped in the J6's, drained the excess oil from the sump, and got it started (for the first time, hot as well as cold). When I turned the LS needle in all the way, the bike still ran ok. Revving it a bit and checking the HS needle, it didn't seem to have much of an effect. And it fouled the plugs after a few minutes (see photo). I pulled the carb and will check the manifold for leaks this weekend, just to be sure.
    1,316
    And don't forget to check the length of both high and low speed needles, as various types are out there and small differences have a big effect.
