Results 1 to 4 of 4
Thread: what is it
    Default what is it
    I'm currently restoring a single cylinder B model Harley side valve generator model, I have a 1926 frame with a 1929 motor 29B1946 and its coming along ok. I have another bottom end with the engine number A2995 and I was of the understanding that the A model was the overhead valve model ? is this correct the casings are similar but a small difference on the left hand side . Any information would be greatly appreciated.
    Aug 2012
    Victoria, Australia
    182
    Magneto ignition side valve.
    Mar 2010
    Western Australia
    78
    Welcome to the forum. If the serial number (SN) is authentic it sounds like a 1926 model as opposed to a 1927 model. SNs for 26 model singles began at 1000 and ran into the 8000s. For 27 model singles the SNs began at 9000.
    Model A is magneto ignition SV as Mark mentioned. More info on the sheet below which was posted by another member a while ago.
    Eric
