Results 1 to 5 of 5
Thread: panhead crankcase
    Feb 2011
    253
    Default panhead crankcase
    G,day can someone tell me if the crankcase mounting bolt pattern on a panhead would be the same as a vl or wla ? I have a bent frame and 3 of my contacts have asked for the rear wheel to be installed with the tranny and crankcase . The crankcase is a right off broken beyond repair , and missing parts too. I don't have a panhead crank to use for the frame guy , Rob
    5,448
    Same as VL but different than 45". Although the pattern is the same as VL the height if the mounts themselves differ. If you need your left case repaired of replaced contact Phil at http://knuckleworks.com/ph4854.html
    Feb 2011
    253
    thanks Chris just what I needed to know Rob
    UL - knucklehead: same pattern, same height difference fronts/rears
    VL - knucklehead/UL: different pattern, same height difference fronts/rears
    Panhead/shovelhead - knucklehead: same pattern, different heights (by 3/8")
    Feb 2011
    253
    ok kitabel cheers back plan B my son has Vl cases so I will need to ask around
