Results 1 to 10 of 10
Thread: Identify this early carb and manifold please
  1. #1
    Oct 2009
    west bend wi
    60
    Default Identify this early carb and manifold please
    Just picked up this carb and intake and would like to know what it fits, it is unusual with the external threads on the carb body. Thanks, Gary
  2. #2
    Oct 2009
    west bend wi
    60
    Default Cleaned up the mystery carb
    Hope this helps on my mystery carb.
  3. #3
    Dec 2006
    1,288
    1913 sears/dayton De Luxe v twin. Maybe. look around for a few photos on line.
  4. #4
    Jun 2001
    Central Illinois, USA
    4,314
    Its delightful, whatever it is, Gary!
    Thanks for the pics for my library.
    Can you measure the manifold spigot thread pitch and diameter?
    They appear right hand?
  5. #5
    Sep 2005
    Sarasota, Florida
    4,166
    That's a Flying Merkel twin intake manifold, circa 1914. The bracket lugs support the compression release assembly.
    Oct 2009
    west bend wi
    60
    Yes I think 13 and 14 Flying Merkel twins, I found a good picture of a 13. Thanks all! Gary
  7. #7
    Jun 2001
    4,314
    Quote Originally Posted by 34 cac View Post
    Can you get a thread count and spigot diameter for Posterity, Gary?
    I keep notes, Thanks...
  8. #8
    Oct 2009
    west bend wi
    60
    16 on the threads an 1.10 out side on the external threads hole in card by threads .94 and inside the manifold threads about 1.05. Gary
  9. #9
    Jun 2001
    4,314
    1 1/8"-16tpi, Gary?
    That's unique!
    Certainly different than anything on this chart (Sorry I forgot who shared it... but thanks!)
    The variety of early Schebs is incomprehensible, Folks.
    One 1" HX crossed my benches that was 1" NPT.
    I just figured out the little 3/4" NPT Hen carbs are actually 24mm bores.
    Now I gotta change my float labels again.
  10. #10
    Oct 2009
    west bend wi
    60
    It is a right hand thread and a straight thread which takes a thin lock nut to keep it tight. It is the only carb I have seen with an external thread and it is built for the ported air sleeve as there are stops on the body for it and the stock air intake for the front of the carb falls in the body as it is bigger. Gary
