Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 62
Thread: Wet sumping question/hard to kick
  1. #31
    Sep 2005
    Sarasota, Florida
    4,145
    I just saw your post Peter. I hope you're feeling better.
    I just went to baseline the carb adjustments and was surprised what I found. The low-speed screw was only 7/8 of a turn open from seated. The high-speed screw was 1-7/8 turns open from seated. The baseline adjustments mentioned in the book are 4 and 1-1/2 turns, respectively. So the low-speed is set far leaner than the baseline, yet the plugs still fouled at idle. Has anyone seen adjustments this far away from the baseline?
  3. #33
    Jun 2001
    Central Illinois, USA
    4,214
    Lipdog!
    Please make certain that your LS needle is 3.5" long, the spring in the knob is on top of the needle, and the lift spring collar is in place with the flat side down.
    I send M344s out set at three and a half turns on the LS, and one and a half on the HS, but that assumes a sealed manifold assembly.
  4. #34
    Quote Originally Posted by T. Cotten View Post
    Lipdog!
    Can I just unscrew it to see? Thanks.
  5. #35
    Jun 2001
    4,214
    Quote Originally Posted by Lipdog View Post
    You will need a screwdriver, Lipdog!
    PS: Here the collar is called a "spring seat".
  6. #36
    Jul 2010
    Vermont
    731
    ...and be prepared for the little spring loaded ball to go flying if you're not careful! (...don't ask me how I know.)
  7. #37
    Jun 2001
    4,214
    Quote Originally Posted by pisten-bully View Post
    I usually have to weld out the LS detente ball, Harry!
    Only if its frozen, of course...
    The choke detente always makes an escape.
  8. #38
    Starting a new thread on the carb question...
  9. #39
    I checked the bike again and it definitely wet sumps. Can that be normal for a newly rebuilt bike? I like the idea of a valve to shut the oil supply while the bike is sitting. Does anyone have a part number/thread size for a valve?
  10. #40
    Aug 2019
    16
    I like the advice of PRG above:
    "(G)etting a kiwi ez drain and a dedicated 5 quart oil container and draining off after a ride if this machine is to sit at all. As that size container permits all the oil to be drained off
    , no measuring required when the next ride comes around, just pour it in and go."
    Simple clean, effective No clouds No worries.
    Have you reached out to your builder? What does he say??
