Results 1 to 6 of 6
Thread: 45 Cam Cover being a bit dufficult to remove
    Nov 2014
    Lynn Haven. FL
    25
    Default 45 Cam Cover being a bit dufficult to remove
    1954 G motor that's been sitting in a garage for 20+ years and I'm doing a tear down to see if it's worth rebuilding. So far it looks promising but, the cam cover's really on there. How do I go about getting the cam cover off without doing any harm?
    2,762
    Are you sure all the mounting screws are out, including the oil pump mounting bolt in the upper left side (there are 12 including the bolt)? There are three dowel pins which can be tight and rusty. Soak them with a good penetrant like Kroil. Gently tap through the generator hole(don't hit the slinger seal!)with a dowel or the like to break the seal of the gasket. And remember, heat is your friend, warm it all up with a heat gun or propane torch. If the top end is still on screw down all the tappet adjusters so there isn't pressure on the cams.
    Nov 2014
    Lynn Haven. FL
    25
    All the screws are out along with the lifter blocks. I'll try some heat around the dowel pins to get things circulating.
    Ohio
    673
    I saw a video from Dale Walksler, I believe, where he heats the entire engine on a hot plate before disassembling anything. Says he gets alot better results.
    Bob Rice #6738
    Jun 2017
    Charles Town, West Virginia
    38
    Kroil, heat, and small no-bounce rubber hammer. Don't try to pry it off! I've torn down several flathead motors and Kroil and patience always worked for me. Pour some Kroil down the tappet block holes, let it soak a little, then gently tap around the edges of the cam cover with something like big screw driver handle. I tore down a UL motor that had been stored in a damp basement since the 40s and that's what worked for me.
    4,272
    As Rubone suggested, TracerBob...
    First drift through the generator hole carefully with a wooden dowel.
    Heatlamps really are useful. Then find any lip you can on the rear of the cover to apply the dowel.
    (I'll have discounted cans of Kroil at Davenport.)
    If no clearance at all is available, or just enough,.. I used some butter knives, cut and trimmed, to tap into the gasket to provide the widest possible leverage, avoiding damage to the machined gasket surface. Good ones have smooth taper from the blade to the handle, making them downright surgical.
    They have seen extended duty beyond cam covers, of course!
    Patience...
