Results 1 to 7 of 7
Thread: 67 Shovelhead 4 Speed
    Jul 2014
    26
    Default 67 Shovelhead 4 Speed
    Does anyone know if there is a tool made to install a main drive gear shaft seal for 67 4 speed, as you know this is a small seal and difficult to get started straight. ? Or any advise on installing one. As always I appreciate the info.
    Sep 2007
    Jersey City
    2,075
    With the exception of turning down a piece of round stock and making your own. I know of non. Just put a socket on it and have way with it. Bob L
    I always bought a couple extras when replacing that seal!
    2,762
    PVC tubing.
    Apr 2010
    1,112
    I make seal installers on my lathe out of PVC like Robbie said.I take dimensions & go to hardware store & buy a pipe or usually connector & turn it down.The seal is supposed to be .050" in from face of case,so I make a step to set to right depth
    Attachment 25565
    Jun 2019
    12
    Nov 2018
    Reno NV
    200
    Jims make a tool, #2256-1, but at around $100, you would need to use it almost daily to make it worthwhile.
