Results 1 to 8 of 8
Thread: Mystery nut - mystery to me anyway
    Jul 2014
    Roswell, GA
    54
    Default Mystery nut - mystery to me anyway
    This nut with a winged flange came with my 1936 VLD bit-sa project, the head is 11/16"
    Can anyone tell me what it does, and what the part number is?
    1936 VLD in process
    1969 Honda Z50 K1 perfect!
    1985 Yamaha RZ350 resto-mod
    2006 KTM 950 Adventure
    2019 KTM 300 XCW
    May 2009
    138
    Front motor mount, under the generator, Big Twin.
    Oct 2002
    455
    A special lock washer goes with the bolt.
    AMCA #765
    2,762
    The nut drops into the case from above, the tab keeps it from turning. As stated, the bolt has a special retaining washer so once it is tight the washer is bent up to lock it in place.
    Jul 2014
    Roswell, GA
    54
    Gentlemen, thank you for the responses!
    Is this nut supposed to fit into a recessed bolt hole in the case? If so, the case was never drilled/machined for it.
    Per the picture, I did insert and tighten the nut, without that retaining washer (I don't have one). If it had a washer [U]under[U]it, the top of the nut would be high enough to contact the generator.
    Here you can see that wear ring, why not just use the same bolt, washer, castle nut with cotter pin as the other 3 holes? The cotter pin might be a trick to get in, but with forceps I'm sure I could manage.
    1936 VLD in process
    2019 KTM 300 XCW
    2,762
    The nut was a new for '36 part and not likely used on a VL, just the new 36 OHV.
    Jul 2006
    Central Florida
    939
    And the UL beginning in 1937, with no washer. The hole was designed to keep the triangular flange on the nut
    from turning at all.
    Jul 2014
    Roswell, GA
    54
    Thanks Sarge, now it goes in the spare parts bin
    1936 VLD in process
    2019 KTM 300 XCW
