Results 11 to 12 of 12
Thread: Valve seals
    The short guides without seals were an engineering mistake by MOCO whose " fix" was external drain lines. Valve seals are an upgrade to any Shovel.
    Nov 2010
    145
    I have used the valve seals and and tools at the top of the attached photo for well over 25 years on Panheads and Shovelheads with good results. No expensive cutting tool to buy and no machining required. The photo is a page from the now defunct Rowe U.S.A. catalog. V-Twin sells the plastic installing tools and the seals. K-Line also sells them.
