Results 11 to 18 of 18
Thread: Seized in pogo
    Apr 2011
    Ontario, Canada
    77
    Could be worse than that, on my first ‘50 frame there was only about the top third of a pogo...however they cross drilled through the frame, spot welded the pogo into the seat tube and then cleaned and moulded the frame. Did a nice job, took me a while to realize it.
    However, it’s much more likely to be rust. Can also be that someone rammed a pogo into a seat tube that had been “modified” to fit an ego or shovel.
    See y’all at Wauseon, if my new heap makes it! (Orange square box Chevy, pretty beat to death)
    Craig
    4,158
    50% Acetone and 50% ATF and you have Kroil at 1/10 the price.
    I agree, Bob; but I have to say that Kroil does smell better.
    4,276
    And a bit safer around the torch, too, Folks.
    Dec 2009
    101
    Here is what one of mine looked like after I got it out, water gets in there and they rust inside the frame, I had a couple like this and helped others, always the same. ( Rust )
    Dec 2009
    101
    Another one, rusted in solid, slide hammer hooked to a chain hoist.
    Oct 2002
    455
    Just make a puller out of iron pipe.
    AMCA #765
    Dec 2009
    101
    I made an iron pipe puller also, when it popped loose, it broke the rod 1/2 way down.
    I welded hole saws to a pipe and drilled small pieces at a time out, broken springs, rust ect, until it was all out.
    Oct 2002
    455
    Thanks for posting that. That's what I use and has always worked with a ton of Kroil and whatever I can put in it.
    AMCA #765
