Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: 1973 Shovelhead Oil Pump Isuues Help ???
    Jun 2019
    Pennsylvania
    23
    Default 1973 Shovelhead Oil Pump Isuues Help ???
    Dear fellow AMCA members, I'm looking to you for help in deciding what Oil Pump to use on my 73 Shovel FLH, as a replacement for my OEM that's not operating properly. I"ve removed the pump and noticed that the body is scored in the areas that house both gears on the crankcase side of the pump body (I've been told this may be the reason for my poor oil pressure that won't operate my hydraulic lifters). I'd like to stay OEM, but from what I've been reading, the 73 shovel pumps seem to have been Harley"s worst ??? I have also been seeing that with some of the aftermarket pumps, that I'd need to drill the crankcase, using a jig to accommodate some new pumps. This is where I'm asking your opinions and/or experience with regards to this action or maybe other recommendations. Thanks for any assistance, she's sitting in my garage and should be riding about now ! Tim in PA
    2,716
    There were several variations of the pump for '73. Any common replacement type would be fine, S&S etc. This is the factory info.
    Jun 2019
    Pennsylvania
    23
    Thanks once again Robbie ! What do think about the aftermarkets that requiring the crankcase drilling ? Also, would you have or know where I could get a copy of Harley's #647 Service Bulletin ? It states in my Service Manual that changes in design and parts were made to the 73's listed in this Bulletin ? I've contacted an old local Harley shop regarding the Bulletin, but no reply as of yet. Tim in PA
    2,716
    I can scan it and send it to you Tim. PM me your email.
    Robbie
    Jun 2019
    Pennsylvania
    23
    Holy Cow Robbie, You are like the "Harley God" !!! I'll have to look into how a PM (private message ???) is done. Tim
    sns pump the best
    Jun 2019
    Pennsylvania
    23
    Thanks ragsflh ! But what about drilling the crankcase with the jig? Does the S&S pump require this approach ? I really don't want to do that if there's an alternative option. I see you're an FLH man, what pump are you running ? Tim
    Jun 2019
    Pennsylvania
    23
    More puzzling pump finds ! Removed both CHECK VALVE PLUG and RELIEF VALVE PLUG and SPRINGS only to find CHECK BALLS in BOTH ports (???). I realize a Check Ball should be in the port closest to the engine, but my service manual shows a #26400-54 Oil Pump Valve in the taller port, NOT a Check Ball, is this correct ??? Confused !!! Another reason I'm looking for that #647 Service Bulletin. Could this be why I not getting enough oil press. to operate the hydraulic lifters, or is this the "so called" mid 1973 design change ? I was able to identify my pump from Rubone's pic as being the Early 1973 version, if this helps ? Thanks so much fella's, she's still sittin idle . . . . ha ha
    Apr 2010
    1,103
    Are your tappets loose in the tappet guides[blocks] ? Are you setting them right?Are the hydraulics loose in the tappet?
    Jun 2019
    Pennsylvania
    23
    Hey there Duffy, thanks for the reply ! SORRY this is so long, but I want you to have ALL the info. I can only assume all what you are asking is fine. A Harley mechanic, who took out the solid stuff (existing in my engine) and installed all new hydraulic parts found out that there was a problem with inadequate oil pressure to operate the new hyd. parts and re-installed the solids . He stated that I should replace the oil pump this winter, but go ahead and ride til then. He suggested installing the hyd. units back in, while I was commenting on the tappet/lifter noises when I took him the bike for some other work. Well, this isn't my approach to things not working properly. I brought the bike back home and checked out the push rod adj., only because the lifter/tappet noises seemed worse. I did find the front exhaust push-rod out of adj. and tightened it up. This is when I decided to removed the oil pump (as suggested) by another Harley mech. and my previous post explains what I found. Hope this helps, Thanks ! Tim
