Results 1 to 10 of 12
Thread: Fork ?
    Default Fork ?
    Hello i am build up jd 28
    But the fork what i have it does not fit.
    Rear fork is type number kc-15D and front fork kc20d
    So question from what type hd these are?
    These are in good shape if someone like to swap..
    It may be the 1922-23 74" / 1924 61"and 74" version.
    What's the distance from the underside of the bottom crown plate to the centerline of the rocker stud hole?
    Mark
    Mark
    Thank you Mark!
    These are like this. 1inch =2,54cm
    What are these
    Quote Originally Posted by Juha_Lahtinen View Post
    Better picture
    Sep 2007
    Jersey City
    2,074
    If your tape is right they are both early forks 1922-24
    Thanks .. what type of harley these are from?
    Is there any who are intrested to swap to 26-29 jd forks
    Br Juha
    Apr 2009
    685
    Br Juha
    I can't use your Forks but I do have a rear leg and leg only for the late fork that uses a front brake for $450.
    I was told it is for the late 20's??? USA UPS Ground Shipping only please. 46EL
    Hey thanks i am intrested . Can you send picture. Glimsradio(ad)gmail.com
    I am travelling monthly in usa so shipment is not problem..
    Your rear leg is correct for 1922-1923 74" as well as 1924 61" and 74"
    Mark
