Results 1 to 10 of 15
Thread: 38 frame identification ①
    Feb 2010
    ***an
    93
    Default 38 frame identification ①
    Hi here、
    any idea..?
    this is a 38 frame I was told. I realized some #s on it... please refer the pics attached.
    looks 404.. 202...4... these are original stamp or what? please advice.
    tks
    Shin
    1,292
    I have a 1938 frame here with a UL motor in it. Bruce Palmer's book was most useful in dating it. It has the closed end axle clips, no dent under the frame to clear the later 74 cubic inch cylinder heads, and no die numbers on the engine mount forgings.
    Apr 2008
    892
    Hi Shin. The casting numbers look original Harley but your not showing the parts that will define a 38 frame. Is the left axle carrier undercut in the machining of the axle slide. Does the left axle carrier have a cap tack welded on the end. There's more info that the experts could give but if you post a pick of the left axle carrier and maybe left side of the neck and the cross braces under the oil pump, you'll get knowledge from some of the people who know.
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
    2,680
    The dash/speedo mount has been replaced. Those are also non-standard welds by the rear stays to top tube.
    May 2009
    128
    I have what I've always believed to be a '38 frame. The left axel carrier has a welded cap at the brake anchor. I don't understand the meaning of "undercut".
    Apr 2008
    892
    Quote Originally Posted by larry View Post
    Hi Larry.
    If you clean the road grime off the part you have pictured, you will be able to see that instead of a raised axle slide, (the area that the axle slides along) it is undercut. The machinist has cut it away and the machining is undercut into the part.
    Regards Steve.
    Steve Little
    Australia.
    AMCA member 1950
    Jul 2006
    Central Florida
    928
    Show a pic of the other side of the left axle carrier in your Post #5. Q is about how it's machined on the other side.
    Feb 2010
    ***an
    93
    thank you guys! any advice about the#s 404..... ? please take a look closely..
    Feb 2010
    ***an
    93
    Attachment 25038 how about this sidecar loop. looks original to me but no casting#. grind off or repop..?? advice please. Shin
    May 2009
    128
    There is no raised portion at the axel slide. It appears to be as forged.
    The inside surfaced is raised.
