Thread: 1918 J Oil Pump
    Jun 2019
    2
    Default 1918 J Oil Pump
    My cam case cover is missing the part of the oil pump which I believe is called the rotary valve. I do have the plunger and spring. I don't see a part number in the parts book but perhaps it was originally available only with the cover as an assembly? Looking for the parts needed. Thanks.
    Dec 2015
    Blighty
    272
    Here are all of the "oiler" parts listed in my up to 1921 parts list
    John
    Jun 2019
    2
    Thanks, John. Yes, That's the same listing I have. The rotary valve is missing from the list. This part might also be called the operating shaft. I have seen both names used. Photo #351, part #GA849 describes the cover and oiler complete. I am guessing that the part I need was supplied only fitted to the cover originally. Jim
