Results 1 to 10 of 11
Thread: WL oil gauge
    Feb 2010
    ***an
    93
    Default WL oil gauge
    hi there,
    one basic question.
    oil level should be between danger and refill line.... right?
    tks
    Shin
    2,649
    No, it should be above refill line. Refill line means it is a quart low.
    Feb 2010
    ***an
    93
    thanks! .. so. upto where should be enough? I think the tank should not be filled up .. as the vent pipe should not be covered .....
    Nov 2018
    110
    if your gearbox is dry, look in the manual for the correct amount of oil. Fill the box with that amount. Put in the dipstick and make a mark where the oil level is. Now you have a permanent high level mark.
    2,649
    Quote Originally Posted by aumick10 View Post
    Not a gearbox, a 45 oil tank.
    Nov 2018
    110
    Sorry, same process
    The tank should never be full, there must be an air space to allow for expansion due to operating temperature.
    The engine will run as long as there is any oil going to the feed pump, this is not like a car engine where the pump pick-up must be covered. If the oil level is low the oil temperature will rise but the pressure in the engine will continue.
    If you are running a servicar install a square shovelhead oil tank under the seat with a dip stick and filter all in one and gain the extra space for gas. Just My 2 cents worth.
    2,649
    Factory specification..
    Feb 2010
    ***an
    93
    got it!! thanks!
