Results 1 to 5 of 5
Thread: Reproduction bearing cups
  1. #1
    Jul 2002
    5,432
    Default Reproduction bearing cups
    Has anyone used the reproduction ball bearing springer cups from V-Twin? Yea or Nay?
  2. #2
    Aug 2004
    Beautiful Northern New Mexico
    2,718
    My experience with them on a friends bike was that both the cups and cones are too thick causing the overall stack height to be such that the top nut was nearly flush with the top of stem. I had to set them up in the lath and grind seating surfaces on the cups and deeper radius on the centering part of the cones to allow them to stack to factory height. A huge PITA!
  3. #3
    WOW Robbie!! I had the same exact problem with the V-Twin cups and cones! Imagine that. Fortunately my machinist (Big Lake Bob) solved the problem. Like you said, PITA.
    Dave
  4. #4
    Aug 2004
    2,718
    Yup Dave, My friend couldn't install the steering damper after assembling the forks. Stack height was so high the rod wasn't long enough. Lucky for you you had Bob. He is a way better machinist then me!
  5. #5
    Jul 2010
    Ohio
    657
    Also, Tedd's cups were not as hard as original, I was able to cut the race with a lathe tool to adjust the above mentioned stack height.DSC05416mp.JPGDSC05417mp.JPG
    Just to clarify, the orig race was 64Rc and Tedd's was 41Rc using a Rockwell scale hardness tester.
    Bob Rice #6738
