Results 1 to 2 of 2
Thread: Front fork and trailing link question
    Feb 2019
    13
    Default Front fork and trailing link question
    Here is the photo , i will post few more later . I am trying to preserve as much as I can including whatever is left of the paint but however need to inspect for cracks and any other issues . My first question is on the leaf springs , is this correct set up because all the photos of finished bikes I have seen it shows them in descending order from top the longest and moving down for each shorter from top. However mine is opposite . Is this different set up or just incorrectly assembled ?IMG_5762.jpgIMG_5764.jpgIMG_5773.jpgIMG_5774.jpg
    Jul 2017
    NW Ct.
    70
    The setup you are showing in your picture is correct for the front end that you are showing. Hope this helps. Smitty
