Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Linkert Carb over flow
  1. #1
    Aug 2017
    Austin, TX USA
    35
    Default Linkert Carb over flow
    I'm still working on my 1941 Sport Scout. I got it running but today the carb was over flowing with gas. Am I right to assume that the float is stuck?
  2. #2
    Or the level is too high, or the needle & seat is leaking
  3. #3
    Aug 2017
    Austin, TX USA
    35
    Thanks, I'm gonna have to take it back off and have a good look. I'm pretty sure I set the level correctly.
  4. #4
    Aug 2004
    Beautiful Northern New Mexico
    2,683
    Make sure the float is off center the correct way. That prevents it from hanging up on the casting on the carb body.
  5. #5
    The service manual level is only correct with an original or exact replica float. Several aftermarket floats require different settings due to their weight.
  6. #6
    Jun 2001
    Central Illinois, USA
    4,078
    Lux!
    Please be certain that your bowl is also indexed with the valve beneath the HS needle, or as close to the choke mechanism as possible.
    The only way to determine if the float is hanging-up against the bowlstem or side of the bowl is to flip the entire carb and bowl upside down, and suck upon the valve to be certain it is fully shut in that position.
    Beware also of some productions of floats that are not only boatanchors, but those that may swell in modern fuels.
  7. #7
    Jan 2017
    29
    I had the same problem with my schebler on my 24 scout. Not until we moved the bowl 180 degrees did we find that it did not leak. worth a try???
  8. #8
    Thanks for posting that photo, never saw that before. Is that a military or H-D manual?
    But... can the distance from the edge of the bowl's needle compartment to the end of the airhorn really be 15/64"? The choke shaft alone is larger than that.
  9. #9
    Jul 2010
    Ohio
    650
    Quote Originally Posted by kitabel View Post
    Maybe 1 & 5/64 (69/64")?
    Bob Rice #6738
  10. #10
    Jun 2001
    4,078
    Its an L&L blueprint, Folks!
    And it also lists a float height of 7/16", so it probably wasn't supposed to leave the factory.
    The idle hole spec is bewildering.
    No matter where you index the bowl, you still have to flip it all upside down and suck on it.
