Results 1 to 7 of 7
Thread: 1945 wld
    Jul 2014
    Lafayette, Colorado
    38
    Default 1945 wld
    I would like to converse with some one that owns a 1940 WLD 45 with the (narrow clutch, two bolt transmission assembly) OEM style primary cover assembly installed. I am having a problem, the shifter rod interferes with the inner upper primary panel at the transmission lever end. The back side of the hook end rubs hard against the panel making it difficult to "feel" a shift change.
    Also, does any one know the purpose for the small access hole (trap door?) (mouse hole?) in that same inner upper primary panel?
    Jul 2012
    Inman, South Carolina
    62
    You need an OEM or OEM style shifter lever that uses a clevis pin
    Jul 2014
    Lafayette, Colorado
    38
    Is there a part # and perhaps a source for the clevis pin type shift rod?
    Oct 2002
    435
    https://www.ebay.com/itm/Harley-1941...EAAOSwFLBaTusG
    Shop around. I remember seeing them for 25.00 not long ago.
    AMCA #765
    Oct 2002
    435
    https://feedback.ebay.com/ws/eBayISA...ab=AllFeedback
    Penny has them for a good price. Just ask her.
    AMCA #765
    Jul 2014
    Lafayette, Colorado
    38
    Quote Originally Posted by len dowe View Post
    And whom might Penny be?
    Oct 2002
    435
    The ebay seller on the 2nd link I posted.
    The first link is Colin. He's a great guy to deal with as well.
    AMCA #765
