Results 1 to 10 of 14
Thread: 46 Knuck
    Default 46 Knuck
    I just installed a new belt drive on my 46 Knucklehead because Iím so sick of the oil trail on my garage floor and when I take it to show it off at friends houses.
    When I did this I plugged the primary chain Oiler. So the first time I rode it after a couple of miles It started loosing a lot of oil on top of my front head dripping down the front exhaust and generator.
    Could this be from plugging the primary chain Oiler?
    Menomonie, WI
    1,274
    Flathead
    You cannot plug the primary chain oiler because it is also the crankcase vent. You have to shut the oil off at the pump with the needle and then I reroute the crank case pipe to the rear chain.
    Jerry
    Quote Originally Posted by Flathead80 View Post
    I just installed a new belt drive on my 46 Knucklehead because I’m so sick of the oil trail on my garage floor and when I take it to show it off at friends houses.
    4,342
    I just installed a new belt drive on my 46 Knucklehead because I’m so sick of the oil trail on my garage floor and when I take it to show it off at friends houses....
    Flathead80!
    Lets start with the natural bodily function called 'sumping'.
    That's when a machine isn't put to duty often enough, or far enough, to purge the cases of idle seepage past the ball check.
    Do I understand you threw money at a belt drive just for a hygienic display?
    It would have been cheaper 'n easier to drain the oil tank into a jug.
    Jul 2017
    NW Ct.
    71
    What Jerry said....
    4,342
    Beware also, Flathead80,
    If you installed a seal upon the motor sprocket shaft for your belt-drive, now your cases can fill all the way up.
    5,464
    Be very gentle when turning off the primary oiling screw. If you over tighten it you will break the seat and lose all control.
    Near the center of Kalifornia
    332
    This is starting to sound like a bad idea 46 knuck.
    Thank you Chris
    Jun 2005
    Northern Colorado
    838
    I've had belt drives on several Panheads for years. Pulley alignment during installation is crucial to satisfactory belt life. Make sure you have enough play in the belt, as the pulleys swell up as they warm, tightening
    belt tension. I haven't had a tin primary bike with a chain since the 70s, and would never go back.
    Jul 2006
    Central Florida
    941
    Kevlar primary belt conversion is an unqualified blessing for the old Harley Big Twins. I've had a BDL "kickstart" converson on my UL for years; never had a hint of a problem. But yes, you do have to stop the primary oil at the needle valve on the gearcase on the other side. All that accumulates in the primary cover is black dust as the belt itself slowly (very slowly) deteriorates, but that's no prob. It's as smooth as can be...and quiet.
    I live in the South, but found that belts have improved so much that extra venting of the primary isn't even necessary for the modern Kevlar belts. I've got thousands of miles on mine, and thousands to go with no signs failure. Don't get the belt TOO tight. Leave a little slack. Tight's bad for main bearing/trans mainshaft bearings. Good luck!
