Results 1 to 2 of 2
Thread: Indian Flywheel truing stand for sale- SPECIAL- modified Harley stand
    Nov 2008
    264
    Default Indian Flywheel truing stand for sale- SPECIAL- modified Harley stand
    I have a used Harley orig truing stand for sale. I have it here on the Indian page first because as a 45 year Indian engine guy I modified it for my mostly Indian use. The Harley stand is much heavier duty than the old Indian stand. I've done at least 100 sets of wheels in my 45 years.
    The first modification is the extra, longer "dead end" taper shaft. I used to struggle truing Indian flywheels, sometimes hours. So I started truing each flywheel to each shaft first. This makes the assembly truing much faster. I had the longer shaft made so it would do this.
    The second modification is a drilled and tapped 2 extra holes in the dead end of the casting so 80" flywheels with the long drive shaft would fit. They don't fit in Indian stands.
    I'm listing this on the Indian site first and as local pickup only. Safe packing this would be a battle, it weighs 60 lbs. I'm in Lakeland Florida, between Tampa and Orlando. I'm looking for $900 for this very useful tool.
    Please contact Bob direct : cdf6333@hotmail.com
    Nov 2008
    264
    I can't find the EDIT POST or REMOVE POST but this item is sold. Sorry, it went to a Harley guy.
