Hello Forum members ,
Trying to find out model of this frame , and year is first 2 digits ?
THANKS IN ADVANCE
THANKS IN ADVANCE
Yup, first two digits. The model is the F.
This is unknown to me hand stamped numbers on Harley frame what years was this done, where might they be . Thanks
Robbie, Am I wrong? I was once told all the frame numbers had F on them whether they were Js or Fs. I am not challenging you on that it is just what I was once told. Hard to tell by the pictures but it looks like the stand studs on the rear of the frame are swaged(riveted] on as are the ones on my 25 frame. Am I wrong or were these only swaged into the frame for a few years? It seems to me the later ones are held by nuts.
Cam
Cam
You are correct about the letter always being F. The frame pictured above is a 1925 and it could have been either a magneto ignition model or a generator model. This one however was a generator model as the control coil to the distributor is still connected to the decompression lever.
Mark
Mark Masa
www.linkcycles.com
Here is my project.. FE7A is on to back fork..
Thank you Mark letting know.
Best Regards Juha
