Results 1 to 8 of 8
Thread: harley 1937 U transmission rebuilding
    Feb 2010
    ***an
    97
    Default harley 1937 U transmission rebuilding
    Hi, please advice....
    I just finished rebuilding of 37 U transmission.
    so how many cc oil should be in?
    tks
    Shin
    4,276
    Shin!
    Please fill it to the bottom of the filler plug threads, level of course.
    I'll guess in the neighborhood of 630 cc.
    And please use the same oil as for the motor; Good luck!
    Feb 2010
    ***an
    97
    hi Mr.Cotton, got it! thanks!!
    Feb 2010
    ***an
    97
    Hi Mr,Cotton,
    I use oil single 50 for the motor. same one for the transmission too? not thicker one ... like 80 or 90?
    5,455
    50 or 60. The same as you use in the engine.
    Feb 2010
    ***an
    97
    ok, thanks Chris.
    4,276
    Please note, Shin,
    Oil can only access the main drive gear bearings by seeping past thrust washers.
    A heavy lube would be restrictive.
    Feb 2010
    ***an
    97
    got it! thanks Mr. Cotton!
