Thread: 38 frame neck casting mark
    Feb 2010
    ***an
    93
    Default 38 frame neck casting mark
    Hi there,
    I was told the frame was 38 original ....
    the cast mark DIF in square is almost gone but you could see " 2 " clearly...
    is that common #?
    also , I looked at the neck of my 49 but I do not see any mark on it...
    so.. is that mark only 30's neck? please advice....
    tks
    Shin
    Jun 2010
    279
    #2 was used in 37 and 38, in 49 the die # is in the dash mount.
    Feb 2010
    ***an
    93
    I see, thanks!!
