Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: Linkert Carb low speed needle lift lever
  1. #21
    Nov 2018
    Reno NV
    199
    Tom,
    It was more an exercise in desperation than anything else.
    I couldn't find the correct shaft, so I used what I could get and had in stock.
    Schebler throttle shaft, Linkert lift cam, correct NOS thumb lever, long detent spring etc.
    And to make things worse, I only had a Linkert lift arm at the time, so I had to reprofile the lift cam.
    It all works, but it wouldn't get any points in judging.
    I live in hope that I will find the correct choke shaft one day.
  2. #22
    Jun 2001
    Central Illinois, USA
    4,272
    Getting the peen on the cam right is something, Mick,...
    That I don't want to draw the judges' attention.
    (doh.)
  3. #23
    Nov 2018
    Reno NV
    199
    Getting the flat on the shaft in the correct orientation was the hardest part, not going for originality, the peen was just hit it with a hammer over and over again.
  4. #24
    Jun 2001
    4,272
    Quote Originally Posted by aumick10 View Post
    I don't have that liberty, Mick!
    Schebler must have pressed it before the rest of the shaft was machined.
    Or it would have crushed.
  5. #25
    Nov 2018
    Reno NV
    199
    I just put the shaft in some soft jaws and took it gently.
    Used a small ball peen hammer, taped the cam on and peened over the shaft.
    I filed the shaft OD and flat down by hand.
    Once again, I needed to get my 29 running, so anything goes. I wouldn't sell one of these to anyone, just for myself. It looks good on the outside.
  6. #26
    Jun 2001
    4,272
    Don't tell anybody, Mick,..
    But after roll-peening, I often silver-solder, just to "nickel" the cam.
    Then I lathe dress the 'upset', with a little center pip.
    I can spot mine in a heartbeat; Still aughta charge more.
  7. #27
    Nov 2018
    Reno NV
    199
    If you are supplying these as a service, that is the type of thing you need to do.
    I have a DLX66 that needs some work. How is your work load?
    Cheers
  8. #28
    Jun 2001
    4,272
    ..How is your work load?...
    Overwhelmed.
    You can do it!
    I'm here to support you through every agony...
  9. #29
    Nov 2018
    Reno NV
    199
    I will stab myself in the eye first, then figure out how to get some machining done.
    Cheers
  10. #30
    Jun 2001
    4,272
    I will stab myself in the eye first,...
    I should have thought of that.
Tags for this Thread
