Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: 1922 Indian Footboard/brake pedal bracket
  1. #1
    Default 1922 Indian Footboard/brake pedal bracket
    To All,
    Purchased this bike and sidecar two weeks ago from the nephew of the original owner. Call it a garage find.
    At the present time I guess you could say I'm more like a curator of this bike rather than a restorer. So many, and I agree, say don't disturb it's almost one hundred year old patina. However, a few parts were removed and never reinstalled. One could only guess why. I have reinstalled many of them all in original condition with original nuts and bolts. One part has me scratching my head.
    I know it's for the rear hinge points of the foot boards as well as the pivot point for the brake pedal.
    The bracket appears to straddle the frame just below the engine. I am becoming more and more convinced that I have to raise the engine from the frame to sneak the bracket between. If so, it tells me the engine was removed at some point as well as the foot boards and when reinstalled someone forgot to install the bracket first. If anyone has first hand experience please share. Would hate to proceed if there is another way.
  2. #2
    Jul 2010
    Vermont
    745
    Quote Originally Posted by Dr.John1922 View Post
    This is just a shot in the dark, but is there any chance the bracket goes the other way instead of under the motor? Extending towards the sidecar?
  3. #3
    Harry,
    I wish it did. Three things regrettably tell me where it goes. 1. After bolting in the front mounting points of the footboards to the front location, the rear radius of the mounting area is defined. 2. As well, after connecting the brake pedal with the brake rod to the rear mounting point on the bracket, it further confirms the location. 3. My sketch showing the frame clamp concept does not show the pitch of the interior surface which takes into account the need for the bracket to be perfectly horizontal while compensating for the slight angle of the bottom frame rail. I'm nervously anticipating that I'm going to have to raise the engine about 1" from the frame to sneak the bracket over. At present the gap between engine and rail is less than 1/2". It's not enough.
    Thank You for your thoughts,
    John
  4. #4
    Jul 2010
    Vermont
    745
    John, on this bike the bracket appears more like it's in front of the motor.
  5. #5
    Jul 2010
    Vermont
    745
    Um, never mind, I see the pedal is mounted at the rear of the footboard!
  6. #6
    Harry, Yes I'm referring to that rear location.1922 LH_1.jpg The bracket I earlier pictured straddles the frame rail beneath the engine at that location. I was hoping there was a larger void forward of the location where I could get the bracket inserted and then slide it to the spot. " Ain't Happenin" Thank You for the picture. It serves as another means for reference.
    John
  7. #7
    Jan 2008
    177
    The bracket goes on top of the frame on my 1918. It looks to me that if the 2 rear mounting bolts were removed from the frame the engine could pivot up enough to slip the bracket in.
  8. #8
    Tom,
    Yes. If I didn't describe it properly I apologise. The bracket needs to be on TOP of the rail and BELOW the engine. I'll try your suggestion and hope for positive results.
    Thanks,
    John
  9. #9
    Tom,
    Finally had the time and an extra pair of hands (my Father) and got the foot pad bracket in. After removing the chain, oil tank and lines, gas lines , etc. I removed all of the engine through frame bolt rods but for one of the rear ones. I just loosened that remaining bolt/rod and with the use of a jack was able to tip the engine up enough to get the bracket in. As a result the brake pedal and rods are properly installed once again. The re-installation of long removed parts is coming along nicely.
    Thank You for the advice,
    John
  10. #10
    Default '22 Standard's status
    The bike has come a long way since purchased. It's been like making a jigsaw puzzle; finding removed parts, learning by comparing to reference photos many of you have provided, as well as applying basic mechanical logic for the moment the bell goes off in your head and you say " Ah Ha !!! That's where it goes !! " Pretty soon the moment I've been waiting to learn: Does it run ?
