Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 47
Thread: My 101 Scout Cannonball Build
  1. #31
    Oct 2011
    458
    Curius if your thrust washers came from thee flywheel manufacturer.
    My last thrust washers were .002 small on the od.
    I like a full seat,centered on the face.Unfortunately even nos valve in nos cylinder/seat the seat is almost on the outer edge of valve.I would find oversize valves if possible rather than recess the seats more than necessary.In other words if you hit the face 35deg.and it cleans up,dress the other two angles minimally to get 1/8 or slightly smaller(intake),thenfit the valve to the seat instead of the other way around.
  2. #32
    No, I got the flywheel from T&O and the thrust washers from Jerry Greer's. As I mentioned above, the flywheel had a problem with the oil hole drilled in the wrong spot as well.
  3. #33
    Oct 2011
    458
    My under size washers were also recent JG.
  4. #34
    I worked on the valves last weekend. Got all of the seats ground down, very lightly, to 35 deg. and lapped in the valves. I went with sport scout valves but I want to keep the 101's cases and springs. But the sport scout valve collars don't fit in the 101's springs. So I made up four new collars. I bought my lathe just for this project but I never expected to use it so much, or even to make engine parts. I sure hope I'm doing this right. I'm sure you guys are thinking it's just a valve collar but it's the first internal engine part I've every made. I'm just hoping it works.
  5. #35
    First mock up
    Found some issues.
    I’m a 1/4” from coil bind.
    The magneto doesn’t fit under the sport scout’s front cylinder
    The plastic retainer on the transmission’s clutch side bearing is interfering with the clutch hub.
    Under my ‘I have to do things three times to get it right’ theory, I’ve got two more mockups to go.
    WTR : 59
  6. #36
    This build would go a lot faster if I didn’t have to work so much to pay for it all.
    WTR : 57
  7. #37
    Jul 2010
    Vermont
    714
    Quote Originally Posted by d_lasher View Post
    WTR : 57
    Hahaha! I hear you!
  8. #38
    This build would go a lot faster if I didnt have to work so much to pay for it all.
    WTR : 57
    Hang in there Dana! And thanks for posting your build. I had to chuckle when you said I swear I spend more time making tools then using them. So true.
    Im looking forward to riding with you in 2020.
    Kevin
    1916 Indian Powerplus - Cannonball Bike
    1941 Indian Chief - Sonny
    1964 Triumph TR6 - 50 year ISDT Tribute
    1969 BMW R60US
    1973 Moto Guzzi Eldorado
    Etcetera
  9. #39
  10. #40
    I’ve been on the road for work a lot lately and haven’t had much workshop time. But I did have enough time to get one of my magnetos running. Once again most of the time was spent making the tools.
    Here’s my home made magnet charger. Don’t judge it on its looks, it’s mostly scrap parts I had laying around the shop.
    And here’s a video to the test jig I made for my drill press making a spark!
    Many thanks to gharper who gave me some tips on magnetos when I met him in Denver. Mostly just that they’re not black magic and a little studying would be all I needed.
    Kitabel, when I mocked up the engine a few weeks ago, I was .250 inches from coil binding the valve springs. I was able to get it to .5 inches just by modifying the valve keeps, and guides, and putting the gaskets on. I’m using a sport scout head and valves, and 101 springs and cams. So there’s a little bit of mismatching going on.
    WTR : 55
Tags for this Thread
