Page 1 of 10 123 ... LastLast
Results 1 to 10 of 91
Thread: 101 Scout... going to take a while
  1. #1
    Jul 2010
    Vermont
    741
    Default 101 Scout... going to take a while
    Iím am going to try and do a build thread, a crummy one probably, but maybe something I put up will show something helpful to someone elseÖ or to me!
    My starting point is a frame purchased this summer with sheet metal and wheels from Ross in Manitoba, they look to be 1928 or 1929. And then thanks to a tip from Indianut I was able to purchase a 37ci motor from Norway, it is a 1930 motor. Iíve been casually collecting other parts (magneto, generator, generator drive, brake leverÖand not done yet) and Iíve started assessing what Iíve got and what I have to do get this Scout back on the road.
    Hereí how things looked after receiving them:
    this is actually a picture from Ross before I got the bike:
    and the motor right after I got it:
  2. #2
    Jul 2010
    Vermont
    741
    The first thing I did was to clean the motor and take off the heads. I could get the motor to turn over about 270 degrees but then it would stop, so I wanted to see why. so off come the heads, I soaked the head bolts in PB Blaster and candle wax, tapped them lightly with a hammer and on the second day I was able to get them all out without too much effort. Front cylinder was gouged from a wrist pin clip! It also turns out the front exhaust valve was stuck badly (took me a week of soaking, heating, tapping to finally get it out… I wanted to save it so no heavy handed persuasion on my part)
    front wrist pin had been replaced with buttons:
    wrist pin clip must have damaged the front cylinder, so maybe the solution then was to install buttons and ignore the gouge"
    pistons are not original, I haven't checked the bore yet
  3. #3
    Jul 2010
    Vermont
    741
    So then I got to looking at the frame, and I noted a weld bead along the lower tube just ahead of the kicker, plus more welding on the brake shaft casting and on the kicker stud casting area. The kicker stud was an offset type and it was bent and tack welded in place. the brake cross shaft was not going to move but I wanted to save it so more soaking, more heat, more tapping on both the kicker stud and the the cross shaft. I also wanted to see if the 2Ē long bead of weld on the lower frame tube had penetrated well and wasnít hiding a crack.
    the old kicker stud, it was tack welded in place
  4. #4
    Jul 2010
    Vermont
    741
    I also have been assessing the rest of the bike, I’m going to need fork work and handlebar work at the bare minimum to make this safe. the LH handle bar looks fine, the R H bar look like a piece of rope with all the creases in it… probably not safe.
    one of the bends in the front fork
    and the ugly RH handle bar
    three clips on the front fork, not certain what they held
  5. #5
    Jul 2010
    Vermont
    741
    and then thereís the tankÖ. ugly for sure but maybe itís salvageable as it I donít see any pinholes from the outsideÖ so I split the tank to see what Iíve got.
    bottom of the tank with some brackets made and the original holes filled in
    and after the split
    So I'll try to do updates, but those of you who have done these build threads have my admiration... it's not easy to take pictures and post them up with some writing. I'll do my best as I go along... slowly!
  6. #6
    Apr 2014
    214
    Nice work Harry, if it turns out as nice as the Chief you're going to have a hard time deciding which one to ride!
  7. #7
    Oct 2013
    Maryland
    278
    I'll be following along! Looking forward to this.
    Dale
  8. #8
    Sep 2005
    Sarasota, Florida
    4,157
    You'll have years of fun with it, Harry Just like going up hill; you'll be half way to the top, look back, and be amazed at how far you have come. If I get a title for my free Honda, I'll be right there with you in new territory.
    Yay. I love a bitsa-build.
    Kevin
    1916 Indian Powerplus - Cannonball Bike
    1941 Indian Chief - Sonny
    1964 Triumph TR6 - 50 year ISDT Tribute
    1969 BMW R60US
    1973 Moto Guzzi Eldorado
    Etcetera
  10. #10
    Jul 2010
    Vermont
    741
    Thanks fellas! I complained about myself on another forum about jumping around the project from one thing to another without focusing on finishing a specific thing before starting another. But at this stage I think that's working for me...I'll eventually zero in on an area and focus on it (e.g. frame...or motor...or sheet metal), but for now I'm still in the "exploratory" phase!
