Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Tachometer part# 92051-65
    Mar 2017
    283
    Default Tachometer part# 92051-65
    I have a complete tachometer correct for my 1969 flh, but I am hesitant putting on my bike because I have to drill through my headlight bucket. Any opinions and will it hurt or add value?
    Jun 2010
    294
    No you don't.
    Mar 2017
    283
    Boy I'm glad to see that, I sure heard wrong then. Is there a cable with a 90 degree bend that fits under the tach mounting bracket? The cable I have does not seem to fit, part# 92062-6SA.
    I have this bracket:
    https://www.ebay.com/itm/Vintage-Har...QAAOSwfiZca7CA
    2,797
    How are you trying to mount it?
    Mar 2017
    283
    I am bolting the bottom of the tach to the top of the bracket. The bracket then bolts to the handlebar clamp cover, but I have not drilled any holes yet. I ran the cable between the handlebar clamp and the nachelle headlight bucket.
    5,464
    Where does this word nachelle come from? Harley-Davidson called it a housing.
    4,343
    PickyPickyPicky, Chris!
    It's spelled 'nacelle'.
    My question is: What color are the indicator lights supposed to be on which side, and how many holes in each side?
    (For '65 ha ha..)
    PS: Thanks in advance as always...
    Mar 2017
    283
    (For '65 ha ha..)
    I post with a kindle which has auto correct and changes the spelling of words it thinks should be there, hence nacelle to nachelle. Maybe the use of "nacelle" upsets the aircraft members. I just wanted to avoid the question of having the correct headlight assy.
    My 1969 FLH has a red light on the left and a green light on the right. My 77 FLH has two toggle switches on the right.
    4,343
    Kindles don't sound friendly, Ryan!
    Seems few nachels are poked the same.
    A fellow who worked at the Factory in '65 told me that some of assembly was often left to the Dealer.
    "As left the factory" requires a crate.
    PS: Late edit..
    My '65s have the square-brooched hole for the tach drive. I coulda had one more toy!
    Mar 2017
    283
    Yes, the kindle is a pain sometimes.
    I have distributor cable adapter 92097-65. My tach needs the aluminium glass ring replaced. I have one, but would rather send it out somewhere just in case of whatever.
