Results 1 to 10 of 13
Thread: 1946 Chief wiring harness needed!
    Default 1946 Chief wiring harness needed!
    Gentlemen,
    I am looking for a wiring harness for 1946 Chief with a 1947 sidecar! I would appreciate any help locating a supplier or vendor!🇺🇸
    Apr 2014
    215
    Try Jerry Greer: https://www.jerrygreersengineering.c...y=1946&m=Chief
    They have a section for side car parts but I did not see any specific wiring for the tail/brake light. The side car might have a similar wiring like the rear fender on the bike itself.
    Maybe some one else will chime in with thoughts...
    Jan 2010
    in someone's crosshairs
    234
    He sells the cloth wire and loom by the foot along with the terminal ends. You could easily make up the harness for the sidecar.
    Mar 2017
    283
    A good supplier for bulk cloth wire and connectors is http://www.riwire.com
    I know the wiring on harley sidecars, but not indian. Although, I am sure they are simular except maybe for the bike to car plug.
    As for the bike, I am sure any of the dealers can supply that.
    Gentlemen,
    Thank you for all your information!
    I actually found a local vendor in Mentor Ohio, Vintage Motorcycle Supply.����
    Mar 2017
    283
    Quote Originally Posted by Motorcycle Mike View Post
    Gentlemen,
    Which one is that, CMS? I live in Ohio.
    Jun 2007
    Catonsville,Md.
    175
    Good place to get correct color wire with correct tracer color and they will loom it also.
    IMG_20190316_155500.jpg Just returned home with my new American Made wiring harness!
    Mar 2017
    283
    That's great Mike, glad you were able to get it so quickly. Do you even have any wiring in your handlebars? I always like that type of work. I have to finish wiring my 69 FLH with sidecar.
    Thanks, I was amazed that I found it locally and made here! The only wiring in the bars is for high/low beam and the horn. I am removing the sidecar harness and taking it to him for duplication. Good luck on your project! ����
