Results 1 to 6 of 6
Thread: New - Driftless Chapter
    Default New - Driftless Chapter
    About 5 yrs in AMCA- Driftless-Wis & Viking-MN member. Stuck on Norton Commandos, so far. Mostly hang out in accessnorton forum. Just semi-retired so I can get one bike back together & ride more. 20171201_114555 (1).jpg
    Sep 2009
    Alaska
    114
    Welcome rhudson, thats a sweet commando you have.
    Steve
    welcome aboard
    Jun 2015
    281
    Welcome rhudson - You might consider doing a "Member Build Thread" documenting bringing your Norton back to life. Look through some of the build threads you may find they are addicting. The threads obviously are a little work as you take photos of your work and then post them and your comments. But as you solve your problems (or raise problems you haven't solved) you get some great feedback, support and encouragement during your build as well as help someone else that will be following your path in the future.
    Here are links to threads with the most recent posts in the Member Bike Build forum just as examples.
    27 JD Cut Down Project by Steve Swan
    http://www.antiquemotorcycle.org/bbo...n-Project-SWAN
    1922 Indian Footboard Brake Pedal Bracket by Dr.John
    http://www.antiquemotorcycle.org/bbo...-pedal-bracket
    1935 VLD Reassemble by Chessie Jake
    http://www.antiquemotorcycle.org/bbo...VLD-Reassemble
    Mike Love
    AMCA Forum Moderator
    Thanks for the welcomes. Mike, thanks for suggestion on the bike build. I look at that on accessnorton forum, and would post here also when I get going on it. Have a few things to do on my rider to make sure I get to this years events- Viking meet & Blind Lizards in June. Hope to do more teardown this summer.
    Rick
    Jun 2015
    281
    Good Luck!
    Mike Love
