Results 1 to 10 of 11
Thread: Inlet manifold 1941 knucklehead
    Jul 2017
    Netherlands
    25
    Default Inlet manifold 1941 knucklehead
    Would it be safe to say that all (late?)1941 knuckleheads had a brass inlet manifold?
    According " Palmers" the change into cast iron ones was introduced in '42..:
    "The brass inlet pipe was soon replaced by a cast iron one for 1942-1947 models, but until the new pipe was available,all future 1941 models were assembled with the brass pipe and bushing well oiled"
    The manifold on my late ( Vin 41EL61xx ) is cast iron but should it be brass?
    thx Rein
    Menomonie, WI
    1,232
    I do not think any of the 41's came with a brass intake. The only original bikes I have seen with a brass intake are 1947's.
    Jerry
    Quote Originally Posted by nukkel View Post
    thx Rein
    3,961
    I agree with Jerry!
    Invariably the OHV brass manifolds that crossed my benches were '47s, and I have encountered U and Servi manifolds that were from late '46 and '47 machines.
    And thanks to a forum member, here's a WL cast -43.
    They are cheesy post-War ordinance scrap. Wasting a strategic material at the beginning of a war would have been treasonous.
    Jul 2017
    Netherlands
    25
    thanks both Jerry and Cotten!
    Quite a different story..!
    So no point in buying a brass one for a 41 knuckle !
    Rein
    3,961
    Once its "cad", Rein,..
    Nobody can tell the difference anyway!
    The last brass that came through didn't have porosities, but there were obvious inclusions when the spigots were cut.
    Here's some more leakers...
    PS: Late edit: Found my photograph of the inclusions still on the camera. It hadn't been developed yet.
    Jul 2017
    Netherlands
    25
    There seems to be a lot of contradicting info regarding these brass manifolds being either 41 or 47..( also on other fora).
    I checked my own manifold that turns out to be an extended steel one, which can be seen in the picture.Never had problems with it though but the more I look at it I want to replace it!
    I was able to buy a 74 brass one and am going to use that one instead on my 41.
    As Cotten already stated, as soon as it is cad plated (steel or brass) no difference can be seen..
    A giveaway could be being not magnetic or the spot where the choke rod rubs along.
    Also at its bottom near the flange it has kind of an X mark where the steel ones have a drop form mark.
    The brass ones are much rarer and the moment they turn out being "definitely 41"(?) I already have one..
    present extended manifold
    brass 74 manifold with x mark
    Steel manifold with "drop" mark
    On closer inspection the rear manifold nut is the wrong type for 41 so that will be taken care off as well.
    Rein
    3,961
    Rein!
    Notice how your brass manifold has squished spigots.
    That's not unusual for steel manifolds as well.
    You will want to swage the spigots back out before re-cuttng and fitting with seals.
    PS: If they were really made in '41, why aren't they bronze?
    5,360
    Long time H-D Dealer Andy Verrone told me that the brass were indeed 1941. However most got changed out because the packing galled on them and they leaked. Wartime restrictions on brass were not in effect yet in 1941.
    Here is a 503-39 WL intake made of brass.
    3,961
    So why did they go back to brass after the war, Chris?
    Menomonie, WI
    1,232
    Chris
    In 40 years of looking I have never seen any even remotely original 41 with a brass intake. I can point you to 10 original paint 47 with brass intakes. Even your buddy Todd when pressed to go put a magnet to an original paint 47 had to admit that it did not pull it.
    Jerry
    Rein!
