Results 1 to 10 of 10
Thread: 41 vin #
    Default 41 vin #
    Good # or otherwise??
    5,417
    Not factory font.
    This is what it should look like.
    Jun 2010
    279
    Not a factory stamp
    Menomonie, WI
    1,243
    Chris Someone did a repair with out getting into the serial number - that's tricky. Weld is a bit porous but probably will hold.
    Jerry
    Not factory font.
    4,073
    Jerry
    I used to know TIGmeisters who did much, much better, Jerry!
    But one died, another got old and cranky.
    The lone survivor is tired of my loser gigs.
    So now everybody's a welder; An associate brought me a right case with MIG work from a local speed shop that looked like a bird's nest.
    PS: The repaired crack to the right of the number boss is painfully typical.
    I blame it on the design of the baffle inside
    Nov 2008
    Virginia
    480
    I suspect the OP pic is of a factory replacement case for 41 and the old vin was stamped in to the replacement case. Not uncommon on 41 cases especially F and FL models. Unfortunately as Chris points out wrong font especially the 4 and the 1 and the 3 look to be the earlier style. May still be legit if done by HD shop and old case was surrendered. JMHO
    Tom (Rollo) Hardy
    AMCA #12766
    Menomonie, WI
    1,243
    I do better Cotton. Probably arc welded and not TIG. Jerry
    2,680
    Regretfully unless the seller has original documentation as to replacement cases or other reasons (dealer invoice, etc) it is merely a re-stamped case and the value is greatly reduced unless just for a rider , as a collector piece it is not good. It all comes down to what you want it for.
    Mar 2010
    Western Australia
    62
    5,417
    The seller is David Wasserman.
