Results 1 to 10 of 18
Thread: Atten, Tom Cotton and Tommo
    Nov 2009
    Reynolds,ND/Queen Valley,AZ
    129
    Default Atten, Tom Cotton and Tommo
    Good day Sir(s) I am working on a Schebler HX 181. I need to know where to find decent quality parts. Mainly I will need a throttle disc (also need the rounded washer on top) or maybe 2 discs in case during the fitting and modification I wind up producing "high grade scrap" out of one of them. Also need throttle shaft but could possible make what I have work with bushings. Also metering needle, I think the book calls for #00. Is the only differences the lengths due to different diameter bodies?
    Now, here is what I am working with; the body appears to have been bored to about 1 3/8 and re sleeved with brass/bronze down to 1 3/16. But they never bored a hole through for the idle speed screw. It still does have the screw. (They must have figured that they had just enough leakage around the throttle disc to make it idle, lol). My thoughts were to use a Sunnen rod/pin hone to bring it back out to 1 1/4 diameter assuming that is actually what it was originally supposed to be. I do know it was supposed to be a 1 1/4 carb. Any and all insight is appreciated. I mainly need to know where to find decent quality parts needed as I am aware that there is some junk out there. You can PM me that info if you wish so as not to start a pi$$ing match, but I would like to know what to avoid. I will also need to make an oversize air valve shaft as that is a bit worn and remember reading about Teflon instead of leather and may go that route.
    Thanks in advance, Cam
    Sep 2001
    Palmerston North, New Zealand
    956
    I've been away at our big Classic M/C race meeting and just got back, away next week for 20 plus days on my 1927 HD and Chair at the NZ National Vintage M/c Rally so sorry for not replying sooner.
    There's a heap of 180's and 181's being done at present and can supply what you want.
    New copper cam tracks are being made as we speak so most if not all bits are available to overhaul these particular carbs.
    I can't do anything for you until I return home on the 26th February and if I don't respond to any e-mails etc. it's just because I don't have the time at present.
    A fit of the guilt's prompted me to reply now.
    Peter Thomson, a.k.a. Tommo
    A.M.C.A. # 2777
    4,343
    And I'm sorry too, Cam!
    I can only offer insights at this time, as health, the weather, and previous committments have me bound.
    The original bore of your 1 1/4" Model was 1 3/8".
    The odds of obtaining an off-the-shelf disc or radius'd friction disc that will fit are *poor*.
    Beware of huge over-sized one-size-fits-none modern shafts.
    I have found, painfully, that even the needle should be cut to fit, sucking upon the nozzle to determine its range of closure.
    It makes a damaged DLX or Linkert needle worthy again.
    For the easy hardware, I relied upon FickauPrototypes@cs.com.
    The rest is up to your own resourcefulness.
    (I cut my own shaft blanks, and fit them individually to the bodies, and splice them into the original shaft's "tower", with the throttle cam indexed to the same pin hole. Similarly, I fit the airvalve with as much of the original hardware as possible.)
    I use PEEK for the airvalve seal, because I have a surplus. I may be able to provide a blank, which you can then mount on a fresh carrier bushing, and lathe-cut to match your fresh-cut seat in the airvalve casting.
    (The price of PEEK seems 'volatile': https://www.mscdirect.com/product/details/63403810)
    There are many ways to skin a cat, but I cut the disc notch while installed, through the idle screw hole, that is blocked upon yours.
    Boring and sleeving a carb is always more trouble than its worth; Honing away only the wear is best, as everything must be custom-fit anyway.
    Wish I could help, but I must clear what is on my benches already...
    Nov 2009
    129
    Sir, There is certainly no need to apologize. You should be out enjoying the rewards of your 27 JD in the first place. I know I would. Also the bike has plenty of other work needed before it runs, hope fully this summer some time. Also a sincere thankyou for your reply. I will most likely be in touch later after you get back. And do enjoy your rally. Thanks again. Best regards, Cam
    Nov 2009
    129
    Sir; Certainly no need for you to apologize either, help from the experts is always appreciated and it really did not take you long to reply either. I wonder why someone sleeved it down in the first place. The rest of the carb does not really look all that bad either. Nickle is thin but probably 75% there. I guess my best bet would be press the sleeve out and hone round and smooth. Actually they appear to have done a rather decent job on the sleeve but no idea why they would of done that. Just wondering is there a reason not to just hone the carrier bushing and make new shaft? Weight maybe? Are new carrier bushings available? A couple other thoughts: any reason that making a pilot to touch up the seat with a valve grinding stone and then making PEEK or Teflon to fit on same angle? About what angle is the throttle plate when closed? I would also guess that you would start with a throttle plate slightly larger diam and the cut the angles on edge in a lathe or how about doing this in a valve reface?grinder machine? Or am I overlooking something here? I think maybe the angle may be different at top and bottom compared to side edges. Again thankyou much for your time as you are certainly busy. Best Regards, Cam
    Nov 2009
    129
    Tommo, PM sent
    4,343
    Quote Originally Posted by camsaure View Post
    I'm no expert, Cam!
    Just a student.
    Without holding it in my hand, I cannot say if its worth removing the sleeve or not.
    But you definitely want it round.
    Honing the carrier bushing is an option, if it is worn concentric. Weight concern would primarily be at the valve itself. It all gets 'weighed' for spring tension anyway.
    Since I cut my own, I know of no modern carriers on the market that I would trust.
    I recut the seat with NEWAY cutters piloted off of the adjustor screw holes, either 45 or 60.
    The airvalve itself I cut as shown, after assembled upon the rod stock before boring and parting off.
    I find most discs are about 10, but it varies how they cross the idle screw.
    More when I can,
    Nov 2009
    129
    Thanks, Appreciated the replies, gives me something to go on.
    Nov 2009
    129
    I have a couple more questions Tom. First off I would like to purchase enough Peek from you to make an air valve. Second: I pressed the sleeve out of my carb and the bore should clean up with very little material needing to be removed. I can see if I look hard enough the wear marks where the throttle plate closed against the bore, but cannot feel it with my finger. I figured out how to make a new throttle plate, but there is no brass rounded washer for the top of the throttle disc. I bet Peek would work great for that also, but is that part really needed? I would assume it is for thrust only, but would help slow wear in the top of the bore. That would be a bit more difficult to make. But it seems Linkerts work without this type of setup. Thanks, Cam
    Nov 2009
    129
    I also forgot to ask above. Have you any of the HX horseshoe floats?
