Results 1 to 5 of 5
Thread: 1968 FLH Mirrors
    Oct 2018
    Michigan
    15
    Default 1968 FLH Mirrors
    Which mirrors would be on a 68, round #91877-66A or square #91879-67B? Maybe my numbers are not correct, I don't know. All(I think) I've found out is the stems will have HD on them and a black gasket around mirror. Where mirrors an accessory and that is why the different part numbers? Or is the round one a 66 year only? Just trying to learn and know what to look for at the swaps or repop if I have to. Thanks
    Think Spring
    Bill #34485
    68 FLH
    Oct 2018
    Michigan
    15
    Quote Originally Posted by jorrow View Post
    Maybe? Isn't that stem used with a seperate handlebar clamp? The aftermarket mirrors I have now are mounted to lever handlebar clamp. From many pictures I have seen that is the way it should be?
    Bill #34485
    68 FLH
    Jun 2005
    Northern Colorado
    840
    A 68 would have had round mirrors mounted to the hand lever brackets.
    Oct 2018
    Michigan
    15
    Thank you sir
    Bill #34485
    68 FLH
