Results 1 to 10 of 15
Thread: Weston 354
    Nov 2009
    Reynolds,ND/Queen Valley,AZ
    127
    Default Weston 354
    Hi All, I am trying to convert an old Weston 354 ammeter that is 30 amps to the ten amp style, My 30 amp has only 1 turn of fairly heavy wire. Way back in the late 70s I rewound the amp gauge for a 30 VL and I seem to recall that it used a bit lighter gauge wire and had more turns. Does anyone happen to know he gauge wire and how many turns to make mine a 10 amp? Any help/tips would be appreciated. Thanks, Cam
    4,042
    I don't know if this will be any help but the 10 amp meter on my 1924 Big Chiefs was inscribed with "wind 2 turns", or words to the affect. I can't recall the wire gauge.
    Jan 2009
    115
    This is a H-D bar & shield 10 amp model 354, wire diameter measures .032 which translates to 20 awg. Appears to have four turns of wire.
    Nov 2009
    127
    Perfect, Thanks a bunch!!
    Sep 2007
    Jersey City
    2,054
    Be great if ya can throw up some pictures of your work on this as you go along. Bob L
    Nov 2009
    127
    OK, I will try to take pictures and report on progress. I just ordered some 20 ga enameled armature winding wire. should be here in a couple days. It could be entertaining to watch an arthritic, fat fingered, shakey old fart struggle through this. LOL
    Nov 2009
    127
    I wonder what the forum did with your picture. I finally got everything I needed to proceed and your picture is gone. DANG
    Nov 2009
    127
    First carefully/evenly pry off bezel and crystal. then remove the 3 tiny rivets from case.weston1.jpg
    Nov 2009
    127
    Remove round nuts from back and carefully remove innards from case.weston13.jpgweston2.jpg then you will find a sort of bridge over needle pivot held by 2 very small nuts. Also remove a black cover secured by 2 small nuts. Did I mention to do this in a very safe place so you do not lose or drop any of this hardware?(don't ask how I know). The needle assembly is extremely fragile so carefully lift it out and place in safe place. Then 2 sort of pedestal screws holing the faceplate and remove it.
    Nov 2009
    127
    The repop face plate has a slightly different opening on lower edge then the original. weston3.jpg To remedy I simply placed the new face on top of the old face, works fine. But I am getting ahead of myself here. The next step is carefully lift straight up a black ferrous horse shoe shaped ring.weston4.jpg You will then find another bridge over the windings. remove it. The 30 amp meter had only 1 turn of heavier wire wound around each of the 2 poles. These wires can be snipped near the solder lugs, be sure to leave enough wire to be able to facilitate unsoldering. I would advise against prying open the lugs, they are brittle and will break off. The old wire is heavier gauge then what you will be using so you should still be able to insert the new wires. You can then slide the wire windings off the 2 poles paying very close attention to directions they are wound so you get your new ones right. There is insulating paper around the poles that will stick to the old windings as they are basically varnished together. So you will need to replace the paper. You need a small rectangular form to wind your new coils around. What I used was the rectangular portion of a pair of hemostats. It is slightly tapered so you can find the portion of it for the best fit. You then slide the windings over the poles and insulating paper. Then apply a bit of insulating varnish on windings.(I would think Glyptal would work for this also. Then you scrape the insulating varnish from the wire ends, trim to length and insert and solder to the lugs. While making sure to have enough clearance on all sides of wire to prevent shorts in the future.weston7.jpgweston8.jpg Then replace the ferrous horse shoe ring.
